Feeder KO
Verfasst: 6. Sep 2016, 13:04
von pete68
Hello
Lightning has damaged my system KNX power supply .
Fortunately, the damage is limited to the final varistor that has no code and is the SMD type .
I thought I would replace it with the 82541250 pattern of Würth Elektronik .
The model is correct ?
thank you
Re: Feeder KO
Verfasst: 7. Sep 2016, 08:18
was it rearly a varistor, not a TVS Diode 36V ?
Re: Feeder KO
Verfasst: 7. Sep 2016, 09:18
von pete68
oldcoolman hat geschrieben:was it rearly a varistor, not a TVS Diode 36V ?
yes, is a varistor (pcb label = VR2)
Re: Feeder KO
Verfasst: 7. Sep 2016, 13:31
If the supply works without them, try the varistor, or not?
Re: Feeder KO
Verfasst: 7. Sep 2016, 19:12
von pete68
the varistor is in c.c. ,no recoverable information
Obviously the feeder work fine without varistor , but is without protection !
Re: Feeder KO
Verfasst: 9. Sep 2016, 08:00
I think you can also take a 36...40V TVS diode like in every modul
Re: Feeder KO
Verfasst: 12. Sep 2016, 12:15
von Mirko
But if VR was on mains side please don't use the TVS [emoji6] A Varistor 275V should be OK for a 230V/50Hz power source.
