Yes, I tried it as well this way getting a hex downloadable on uC.Hendrik hat geschrieben:Your lpcxpresso installation comes with a tool to convert the binary files. The magic command is
arm-none-eabi-objcopy -O ihex rol-jal-bim112.axf rol-jal-bim112.hex
The arm-none-eabi-objcopy should be somewhere in /path/to/lcpxpresso/lpcxpresso/tools/bin/. Also have a look at http://support.code-red-tech.com/CodeRe ... putFormats. If you have any trouble with it, ask again. I can do the conversion for you, but not before tonight.
No way! the problem remains, after the failure of the PA in the download starts flashing IO2 (??).
This makes me think that my hex is correct (I had the same problem), then, given that, for other people this firmware works and not to me, open up different scenarios:
1) I'm using a vd incorrect ETS file (I use MDT_KP_Jalousieaktor_V28.knxprod but I tried other)
2) The firmware uses a watchdog and Magicflash not allow me to set it (there)
3) I use a 12 MHz crystal while the firmware using an oscillator.
I do not know what else to think.
For the record, only OUT8-BCU1 I work, nothing else. (Bah?)
Anyway, your hex is well appreciated. Who knows!
paschal
